awesome..thanks. trying to build cable to connect to a Motorola dispatch console.
You would be better off pulling signals from the 11-pin J6 internal connector. Get 7-DISC and 3-COR then use an external box like a Midians TTC-2 or CPI-Comm TTP to create an adjustable balanced 600 ohm input/output. The TTP's let you use 2-wire or 4-wire and can also take EIA standard audio tones from a console to transmit via 11-PTT and 9-audio-IN (if that is part of the project). You can also use a JPS PTG-10, with or without pilot tone.
Icom offers a OPC617 which fits J6 inside the radio and terminates with an external DB-9 on a pigtail.
For a long time the F121's (and sucessors) have been the basis for Icom's voting receivers. Typical Icom; excellent sensitivity and rejection.
Tha actual J6 connector is
B11B-ZR-SM3-TF JST Sales America Inc | 455-1296-2-ND | DigiKey. Or, you can (carefully) solder fine hookup wire direct to the J6 pins. I buy 11-pin mating plugs from Midians.com. It is the exact same connector they use for their UD-1B board, and they put 10" wires on for you.
J6:
(Top end closer to C255 & C256)
1- VCC+ (switched 12VDC, 50mA max)
2- DIM (input - program for display dimmer or external ignition sense)
3- HORN (output - program COR low on received signal, >220 ohm pull-up resistor to VCC required for TTP's)
4- GND
5- AFO (low-level gated, variable level)
6- GND
7- DISC (low-level ungated, constant level)
8- GND
9- IN (audio)
10- GND
11- PTT (low to TX)
(Bottom end closer to AF amp IC8 and front board)
