Icom f14
slingshot202
New Jersey
Anyone familiar with programming the F14? I have the VHF version and I can program, connect, etc, however the green light always stays on and when I click the Monitor button or have a channel without a PL I continually receive carrier squelch (static).
Thanks.
Thanks.
You will get white noise when you do not use a pl tone or press the monitor button if you are around different kinds of electronics that give off RF emissions
kb0jfg
Kansas
Green light
There is a setting in the software for the squelch threshhold under I think common setting in the directory tree. Set 130-160 should work
