Icom F3261DT Persistent Beeping
RadioDitch
Field Operations Member
South Padre, TX
Evening all,
I'm not an Icom guy so I'm not great with the quirks. I powered up my F3261DT today for the first time in a while. Conventional systems only (FM and IDAS/NXDN), no trunking, no signaling, etc. Turned on fine, display is normal, seems to function fine. Battery is at 60%. But it keeps beeping every 1 second or so. Almost heartbeat like. Any guidance on the issue or fix?
Now, I admit, it had been carelessly left in the heat of the truck for a few days. But it seems fine besides the beep. I did try a few things. I reflashed the codeplug to the radio from the CS without issue, removed the battery then reattached it, brought it in to cool down and let it sit on the charger for a bit. But none of that helped.
Any help? Thanks!
ComradeGlock
Soviet Republic of New Jersey
I had the same problem with a new Icom F3400DT. Was driving me bat crackers.
Turned out to be the low battery warning I had configured. Took a little troubleshooting as the battery level was at 48% so I initially went in a different direction (thought it had something to do with Priority Scan). Then I had an epiphany and let it fully charge and viola, the infernal beeping stopped.
Hope your issue is as simple!
