WX4GPS
I just received the IC-7100, and I want to use a Green LIght Labs GPS710, and open it and rewire the pinout to work with the mic jack on the rear of the radio, there is 8 volts out. My question is, does anyone know if the mic jack is live on the rear if you have a microphone on the rear of the faceplate?
The greenlight labs takes I believe 6 to 16 volts input, and has an amazing receiver.
My 2nd Question its my understanding, and im hoping someone can verify, if I plug in a TinyTrak 4 in the 6 pin mini din port and have it running 24-7, sending GPS PTT data, I can set the radio only to ackknowledge the PTT only if I have the data on, and I can program that to a memory channel for 144.390 for APRS. and only when then im in memory mode will it then work? or if I choose data mode manually otherwise?
Thanks for confirming if what I am after will work this way.
Ron WX4GPS
Ron WX4GPS
