Icom IC-F320 softwre help!
localhero800
Southeast Missouri
When trying to read the radio, Clone-> read-> it says " wait a moment" and after 15 min, it hasnt changed.. Downloaded the drive software for the cable.. any ideas???
localhero800
Southeast Missouri
Im using an Acer Aspire 5610. I reassigned the Cable to COM1.. and put the Software on PORT1. Does the radio need to be put into a programming mode?? IM not an icom guy, but i like this radio, as soon as i get it programmed correctly, i will like it even more!!
grumps96
Massachusetts
csf300
Hi, The cs you ae using is run in DOS. You need to get a computer that is running windows95 and load the software into it. then when booting up go into DOS mode and open the software. the system you are now using does not really support DOS programs.
grumps96
Massachusetts
I know it open the window, and I know it "seems" to run the program, but trust me I am speaking from experience. You need real DOS not psuedo DOS
