Can someone explain how vsc actually works.
I have a load of airband frequencies programmed into radio vsc was not turned on when. Programed in by butel.
So when scanning if it stops scanning on a noise channel I'll press quick then switch on vsc it will then continue but on next pass of scan it will stop on that channel as noise it detected and vsc is of . If I overwrite the channel with vsc on it stays on.
Then again if I go to a channel that I've overwritten. With vsc on if I turn it off and go back to channel it's back on again ?
