prcguy
I think we are getting similar results with the preamp on and mine seems to break squelch at a slightly lower level without the preamp. If I get time I'll connect an audio dBm meter and find the point where a 30% modulated 1Khz tone produces 10dB more audio than no signal present.
Bottom line is the VHF AM sensitivity is just fine and that coupled with its world class narrow and wide spaced dynamic range and super low LO phase noise means there should be few receivers that could top it for VHF aircraft reception. If you want to see how my personal 8600 does on HF, see the 17th receiver down on this list: Receiver Test Data For some reason Rob Sherwood's personal 8600 did much better and ranks the second best receiver he has ever tested.
For AOR-262, I would really go through all the menus again to see if some setting is causing the problem. If not then send it in to be looked at so you can enjoy it at full specs.
Reading this thread concerned me a bit. I never really use my R8600 on VHF air band more than extremely causally, just occasionally going to the local airport Unicom. So I really had not checked out the R8600 in AM and VHF.
I do not have a SINAD meter. I do have a HP 8640B and a software audio power meter (on the soundcard of one of my machines). So, what follows may not be a true 10 dB S+N/N measurement, but should be somewhat close.
R8600 was set to: 124.000 MHz, AM mode, Default FIL 1, AGC OFF, Pre Amp was tried both ON and OFF, NB, NR, ATT, IP+, NOTCH all OFF.
HP 8640B set to: 124.000 MHz, Internal AM modulation, 1000 Hz, 30% modulation.
I took the audio out of the R8600 directly to the line input of the sound card. I set the audio power meter software REFERENCE to 0 dB (raw number was about -36 dB) with Squelch OFF and no RF signal input to the R8600.
R8600 Pre Amp OFF, Squelch set to 30% (just killed static):
-118 dBm, 0.28 uV, broke squelch with usable but somewhat scratchy audio.
R8600 Pre Amp ON, Squelch set to 30% (just killed static):
-130 dBm, 0.07 uV, broke squelch with scratchy audio.
R8600 Pre Amp OFF, Squelch OFF, Audio Power meter REF set to 0 dB with no signal present:
-112 dBm, 0.56 uV, 10 dB increase in Audio Power meter
R8600 Pre Amp ON, Squelch OFF, Audio Power meter REF set to 0 dB with no signal present:
-120 dBm, 0.22 uV, 10 dB increase in Audio Power meter
Again, I am not going to claim this is a 100% valid 10dB S+N/N measurement, but it should be in the ball park.
It looks to me like the R8600, at least my copy, is adequately sensitive in the VHF Air Band.
T!
