Icom/Kenwood DQT compatibility
RadioNube
Texas
I have a set of IC F4031T handheld radios that I would like to program to join a set of Kenwood TK-3402U16P. The kenwood radios are programmed with DQT on each channel and while I can just remove it from a couple of channels to allow the two brands to interact I would like to know if someone can explain to me how to program the Icom to be compatible with say... DQT D343I. The QT settings were simple selections from a drop down menu from CS-F3020/F5010/F5020 rev 3.4 but the DQT selections are not so straight forward.
Any intelligent response is appreciated.
Frederific
In the C. Tone menu, there should be an option DTCS at the top of the list. Choose this, and the CTone box turns into a standard text box you can type your chosen DCS/DTCS/DQT/DPL code into
On Kenwood radios, DQT is the term used for DCS.
In your example, DQT D343I,
D = Digital
343 is the DCS/DQT code
"I" means it's inverted. You can use the drop down DQT menu to select the correct one.
Let me know if that doesn't work and I can dig into that software a bit more.
