ICOM PCR2500 Antenna confusion
Katy, TX (Houston)
#1
I see that the 2500 has 2 antenna inputs, but the way they work together seems confusing. After some research, I assume that I can hook an HF antenna to the main antenna input and a discone to the secondary input and then bounce between them using dualwatch. Is that right?
The options at the bottom of the PCR2500 page at Universal-Radio says:
"DPX-30 RF Systems antenna combiner allows connection of separate HF and VHF/UHF antennas." Am I correct in assuming that only applies to the IC 1500?
Can some knowledgeable person clear this up?
regards,
Thaellar
So. Texas
#2
regards,
Thaellar
The combiner lets you receive HF and V/UHF/800 frequencies on one receiver, preferably the main receiver. On the 2500, the main has full HF-3.3 GHZ receiver, which without an antenna combiner can become deaf on HF if you use a discone only or deaf on the high bands if you use a longwire or dipole only.
I would invest in the combiner, which will phase the two antennas together and give you a superior receiver. The sub band does NOT have HF receive capability so a discone or ST2 would suffice.
Hope this helps.
~S~
