Icom R2500 data jack
LesWurk
Land of RF
Whats the purpose of this jack, I searched the manual and the web but can not find a answer. It's a 3 conductor 2.5mm connector.
Pape
Quebec
well if I understand correctly you need the UT-118 to operate the data jack therefore it must be something related to HAM usage (d-star).
You have to connect the ground to pin 5 and RXD to pin 2 of a db-9
All this information can be found at page 10 of the Manuel (r 2500)
Take a look here DStar Comms Pro - Communication software for D-STAR Enabled ICOM Radios not sure if it will work on a receiver...
LesWurk
Land of RF
Thanks for the input. I do not have the UT-118.
Page 10 of the Icom R2500 manual is about Windows Driver installation in the manual (Instruction ManuaI) that I have.
Pape
Quebec
if it talk about the drivers you are reading the pcr 2500 book :) in this case read page 43
CrazyCalifornian
San Diego, CA
The Data Jack is used to connect a GPS unt. The PCR can send NMEA messages to the GPS when the propper transmissions are received by the D-Star Module (UT-118).
It can show the received user's location, altitude, speed and direction of travel...
Viper43
The data jack, AKA packet port is for several things but not D-Star specific or GPS specific. Amongst other things it's a 10.7Mhz IF so you can use it as a discriminator tap for programs such as Unitrunker and so forth. It can also be used for numerous other data related programs like ACARSD.
Pape
Quebec
the R 2500 also have 2 packet jack and one data jack "current conversation"
CrazyCalifornian
San Diego, CA
The 2500 has a "Specific" "Data Jack" that is connected to the UT-118 (when installed) :)
The Data Jack is NOT Also Known As the packet port on the 2500...
CrazyCalifornian
San Diego, CA
I should also point out another correction so that PCR owners do not get confused:
The Packet Out provides a "Discriminator Tap" at the audio range (khz), NOT a 10.7mhz I.F. tap...
