ID Antenna
TexScan780D
Can someone ID this antenna. They are starting to show up on the local PD vehicles.
The blade is about quarter inch thick. Round base with the blade.
There's a ton of manufacturers producing these, and it's often difficult to narrow them down from a small fuzzy photo.
But, they are multifunction antennas. Likely you'll find it's carrying LTE for the mobile terminal, GPS for location, and probably WiFi.
TexScan780D
The picture was taken at a distance and I cropped it down.
pretty sure that antenna is plugged into something like a Sierra Wireless RV55 cell modem with GPS. It has 3 sma antenna ports. We use these at work for asset gps tracking with the exact antenna you posted
Likely.
Newer Harris radios will also use similar antennas to permit WiFi and LTE for BeON functionality as well as GPS for location. I just installed a similar antenna on my work truck for one of the Harris XL-200M's I ordered.
TexScan780D
Likely.
I was wondering if Motorola radios might use this antenna?
TexScan780D
Likely.
Never heard BeON, what is it?
Network interface back into the radio system core. Essentially allows access via IP (LTE, WiFi, etc) back into the system. Newer Harris radios can be ordered with LTE and WiFi option to allow this functionality.
Also allows an app on a smart phone to work as a radio.
