ID Tracker III - V1.8.3 Released
K3HY
Delta, Pennsylvania
I appreciate the program as well.
Especially like being able to add labels to the talkgroups and the private id's.
It's nice not having the unit ID's taking up memory blocks in the scanner itself.
Only problem so far is when a new talkgroup pops up and I use the store (F3) option, it triggers a debugger window.
Looked at the ini file and couldn't find anything about turning the debugging off.
It's such a small problem and is the only time I have seen the debugger window.
I'm using a pro-197 and IDTracker III is about all I use for controlling the scanner.
Thanks again for providing a great program.
brscanning
Baton Rouge, LA
If the debug window pops up, it should contain an error message. Could you post or send the error message so that I can take a look at it?
K3HY
Delta, Pennsylvania
It says Scanner image file not found, but I looked and PSR500.bin is exactly where it should be.
ID Tracker III Debug Log
000:00:09.501 Scanner image file not found: C:\Users\Bruce\AppData\Roaming\IDTrackerIII\Data\PSR500.bin
--> 02 4B 0F 03 5D
--> 02 4B 1B 03 69
--> 02 4B 15 03 63
--> 02 4B 15 03 63
--> 02 4B 1B 03 69
--> 02 4B 1C 03 6A
--> 02 4B 16 03 64
--> 02 4B 23 03 71
--> 02 4B 1D 03 6B
--> 02 4B 17 03 65
--> 02 4B 1E 03 6C
--> 02 4B 01 03 4F
--> 02 4B 15 03 63
--> 02 4B 01 03 4F
--> 02 4B 1B 03 69
--> 02 4B 01 03 4F
--> 02 4B 21 03 6F
--> 02 4B 07 03 55
--> 02 4B 03 03 51
--> 02 4B 22 03 70
--> 02 4B 23 03 71
--> 02 4B 12 03 60
--> 02 4B 0C 03 5A
--> 02 4B 19 03 67
--> 02 4B 19 03 67
--> 02 4B 02 03 50
--> 02 4B 08 03 56
--> 02 4B 0E 03 5C
--> 02 4B 0E 03 5C
--> 02 4B 0E 03 5C
--> 02 4B 0E 03 5C
--> 02 4B 08 03 56
--> 02 4B 1F 03 6D
--> 02 4B 0F 03 5D
--> 02 4B 07 03 55
--> 02 4B 07 03 55
--> 02 4B 13 03 61
--> 02 4B 13 03 61
003:16:56.382 Application Error!
Error: Error getting scanner status.
Data: 204C53636E31303837205447525020706C445643202020203530312E3433373530302A49443A20202020202020323030313720202020202054535953202020202020D000309B
Error: Index was outside the bounds of the array.
Source: IDTrackerIII
Stack Trace:
at IDTrackerIII.modGRE.GetScanStatus(SCAN_STATUS& udtStatus)
Module: modGRE Routine: GetScanStatus
brscanning
Baton Rouge, LA
Stack Trace:
Looks like the "Index was outside the bounds of the array." is what is causing the debug form to pop up. I will look into it when I get a chance.
K3HY
Delta, Pennsylvania
For me personally, it isn't worth looking into, now.
Just add it to your list, the next time you upgrade.
The occasion to use F3 to store a wildcard talkgroup is so rare, that I just make a note of the TGRP and enter via PGM etc.
Thanks again for a great program.
K3HY
Delta, Pennsylvania
Another thing that I have noticed is that everytime I do a Reload GRE Image, IDTrackerIII adds another "Aviation" to the systems.
For example, when I click on File and cursor down to Systems, it will show multiple instances of "Aviation", for each time I do a Reload GRE Image.
None of the other Systems duplicate, only "Aviation".
It doesn't seem to affect IDTracker III in a negative way, I just thought it odd.
brscanning
Baton Rouge, LA
Noted. Thanks for the feedback.
