garys said:
Not true. All trunking technology is protected by patents and copyrights. In fact, copyrighting is better protection than patenting. In either case, if someone can reverse engineer the technology they can market a scanner that could decode Iden. That's how we got scanners for Motorola and EDACS systems. In fact, that's how we got the computer tha I'm writing this on. After IBM introduced the PC, other companies went to work on figuring out how to reproduce the result without using the same technology.
That's what makes this country great.
On a slightly different note, someone told me, but I can't verify, that Iden is actually a very slight variation on VSELP.
Gary
iDEN uses VSELP as its vocoder, but that is only one part of the issue.
(Probably the stickiest one from a intellectual property standpoint)
iDEN also uses a modulation that would take some work to decode efficiently in a receiver not specifically designed for it.
You then have to decode the channel and sub channel framing, (which would not be very hard).
Then you have to reverse engineer the unit and group ID messaging.
THEN you put it all together and all you get is users on the one cell you are in.
Edit: One little note, VSELP is a vocoder 'family' with several variations.
(The confusion comes from people who like to use the name of a particular vocoder as a shorthand name of the whole over-the-air protocol. This adds to many peoples misunderstandings) (P.S. I used to rant on this, but got so much crap, I have pretty much stopped, except where it is OBVIOUSLY the root of an issue)(Like here)
The story behind the PC is a little different, as the IBM-PC used many existing industry standards, AND IBM published the BIOS to make it easy to know how it worked.
