There is nothing that will decode IDEN.
Couldn't the output from a scanner be fed to a software package which would then decode it? Or is that too far fetched?
Just out of curiosity, do you know how they get radios that work on iDEN channels? Do they just take nextel-style phones and program them to handle different frequencies or do they actually buy iDEN-spec 2-ways?
do A Search, This Was Discussed Before. There Is A Company That Provides Iden Radio Services To Airports And Such.
May be possible. You'd need to tap the discriminator circuit to get the raw data waveform.
I concur. iDEN has been discussed before, on this same subject in fact, so you can find more infor by searching for just "iden".Do a search, this was discussed before.
I don't think a descriminator is going to give youy a usable outbut from MIRS/iDEN M16QAM
https://idenonline.motorola.com/ideveloper/pdf/techover.pdf
Yep, even with the Astro radios there is no "discriminator". They use what is called an Abacus chip to digitize the IF. From there it's sent on to be decoded via lines that use current loops to carry the digital logic instead of regular gates due to the high speeds that would cause noise. That's why you can't "tap" an Astro radio in the conventional sense. There's nothing to electrically grab on to.
It's not as simple as tapping a chip and decoding.
I don't know if this is possible but what about putting an IDEN mobile or handset into TEST MODE like we used to do on the old AMPS phones? or getting an old IDEN two way and hooking it into some for of a computer program and using the mobile only as a receiver/decoder and let a pc control the trunking functions?
well me personally the phone stuff doesn't interest me. it would be just the PTT/Direct Connect and Group Call stuff.
guess this is what the original poster was looking for also. the way i figure, if they can hack Conditional Access Modules and VCII stuff then for these same people direct connect and group calls should be a piece of cake.
