Identifing Data Signal
Ottawa, Canada
#1
I am interested in identifying this 800 mhzdata signal
They are about 20khz wide and there are lots of them.
Thanks, Mike
Bragg Creek, Alberta
#4
Actually I'm going to throw a dart and say they're iDEN channels, aka TELUS MiKE. 865.6625 is one of the licensed frequencies for it in the Ottawa area.
Unlike the US, Canadian iDEN providers have not turned off the iDEN network yet. Many entities still use iDEN as everything from a "cheap" two-way radio to a full trunked communications network (for good or for bad) here.
I have seen bandwidths in Spectrum Direct from 17.7 to 25 kHz for them.
Ottawa, Canada
#5
Enlarged Screenshot
Here is an enlargement of the signal. It seems to have four "slots" about 5k wide.
I can recover some data audio if I reduce bandwidth, but difficult to describe. Certainly is interesting.
Mike
KevinC
Moderator
Super Moderator
Somewhere other than home :(
#6
X2 on iDEN, especially after you zoomed in.
And it's called a "Bart's head", named for Bart Simpson's hair.
They should technically be 18.54 kHz wide.
Ottawa, Canada
#7
HA!..... I really like the "Barts Head" description!
Thank you for the help. I think Bart has jaundice or some other medical condition.
Mike
