ids
fmsmark
Ct state pd
I am new at this scanner thing any idea what numbers I type in for CT state pd troop h and troop L
LEH
Yorktown, Virginia
fmsmark,
For troop h dispatch the TGID is 5616. Look at the CSP system and find that TGID in the list, then it should be fairly easy to figure the rest of it out. Troop H is central and the table it is in is about half way down the page.
Not trying to be a hard a$$ here, just trying to help you learn what is there and how to use it.
Normally you won't need the HEX values, only the decimal values. You will want to enter the TGID name (something to tell you what the ID is like "Trp H Disp".
fmsmark
Thank oyu for your help I will go to that forum sorry I am new to this whole scanner idea
n2mdk
Ames, IA
fmsmark said:
I have the Uniden BCT-8 trunktracker III
The BCT8 isn't going to work on this system, it's digital the BCT8 is only good for analog systems, sorry to bring bad news.
fmsmark
do you know what scanner gets these channels but not cost a arm and a leg
