IF out is inverted?
Ontario, Ca.
#1
When using dmrdecode I have to turn invert on to get the correct info. Has anybody had this problem? I also have to figure out how to invert dsd so I can hear the audio. Thanks, Gary
mtindor
OH/WV DB Admin
Carroll Co OH / EN90LN
#2
It all depends upon your computer's audio device. For some they need to set inverted, for others no. It's right in the menu on DMRDecode. You can easily toggle between inverted / not inverted.
Mike
Ontario, Ca.
#3
I figured out how to do exactly that and it worked. All the commercial radios and even my motorola service monitor do not require me to invert the programs. I guess its the point in each radio some engineer picks for the raw audio. Thanks, for the info. Gary
Ontario, Ca.
#6
IF Out
Now that makes sense. I modified a vertex handheld to be my portable DMR receiver. Had been using a mobile radio which has IF out on the rear of the radio but is to big to always take in the field. Thanks, Gary
