Blackswan73
If you have Iscan installed on your PC, follow these instructions
Remove the batteries from the scanner
Insert the SD card
Connect the scanner to your PC
Open the Iscan program
Under the “Scanner/SD card” tab select “Prepare scanner memory/SD card for use”.
In the “After Format Options” screen make sure both options are checked.
Select the removable drive letter for the scanner (i.e. Drive E) and click “Format”. Follow the onscreen instructions
Close the program when format is done
Unplug the USB from the scanner and enjoy!
If your card is corrupted and you forgot to back it up. PM me
Insert the SD card
