As has been suggested here, he directly wired the power supply to the radio via a dedicated line to the battery. He's also familiar with bonding and grounding.
Make sure the body of the radio is grounded to the chassis. Do not rely on the long negative lead to the battery, or the coax shield. Long conductors can act like antennas.
Run a ground wire/strap from the radio chassis to the vehicle ground, keep it as short as possible.
I get the fact that a properly installed antenna is key to good RX and TX with any radio, either CB or HAM, but getting maximum performance requires attention to detail and getting everything just right.
Yep, and now that you get it and see how it helps, you can watch the threads on this site and read about those that insist on cutting corners on their install then get frustrated when it doesn't work well. Taking the time to do everything correctly the first time saves a lot of headaches.
7 miles isn't bad, as it can really be dependent on atmospheric conditions, local conditions, terrain, etc.
