dmg1969
I recently (Saturday) installed a Bearcat BC355N in my 2009 Hyundai Tucson with a SpectrumForce Wideband antenna. I am just using the cigarette lighter adapter for power. The scanner is constantly locking onto frequencies (usually VHF low) with constant static. Adjusting the squelch does nothing. It will persist for 1-3 minutes and then the static seems to sputter out almost like I was driving through an area of interference. I also have experienced it locking onto frequencies in the 150s MHz and UHF in the 400s MHz. Those are more of an electrical buzzing noise that sounds like a data channel.
At first, I thought it was the antenna, but I went out on lunch and experimented while driving. When it locked onto a pure static VHF low frequency, I pulled over and shut off the ignition to accessory and the static went away. I did that like 3 times and it seemed to go away each time I turned the engine off.
How can I solve this? The frequencies I want to monitor are VHF low, VHF, UHF, air and CB. I do not need 800 MHz. Right now, the scanner is pretty much useless for my mobile use.
Keep in mind that I am just a scanner hobbyist, not a ham so please be detailed. Thanks!
Dave
Dave
