Ikea Ladda batteries.
scannersnstuff
Looking for review's on Ikea Ladda aa rechargeable batteries. I have been using Eneloops mostly, and am quite happy. But the price ! . Some say Ladda's are rebranded Eneloops. Thanks for any help.
dave3825
Suffolk County NY
I use them and they are half the price of eneloop, who it's believed to be making the Ladda batts. I get around 7 hours in my 436.
I did also hear that the rechargeables that harbor freight sells are quite impressive. I'm actually going to be picking a set of those up this weekend.
jaspence
Michigan
Powered hubs should be a last choice to use with any usb connection. Check the power output with a good volt meter and see what is actually being sent to the radio. Radios that use AA batteries are best charged in a stand alone charger that handles each battery individually. I use an Ikea charger and can do 8 at a time and takes around 3-4 hours depending on the battery capacity.
scannersnstuff
Yes, I am pretty happy with my Harbor Freight rechargeables. I also use them in my flashlights. The Eneloops seem to last forever. I have had several set's for about 5 year's. The other thing is, the Harbor Freights are pretty inexpensive.
N9JIG
Sheriff
Moderator
Far NW Valley
I have a friend who swears by the LADDA batteries, he says they are the best he has used and dirt cheap to boot. Personally however I prefer alkalines. I get them from warehouse stores in the 48 packs so I don't have to worry about charging or managing batteries. I just keep a dozen in the car and a bunch at home.
KC1THE
I recently purchased the Ladda 2450's and Stenkol battery charger. I am also getting about 5-6 hours on my BC125AT. I am still in the 1st conditioning cycle (instructions say 2-3 charge cycles will bring batteries to their full potential).
Great thing is, these things were ready to use right out of the package (as noted on the package) and had a good charge.
I probably won't go back to alkaline or the 2300 mAh supplied with radio; well, maybe as an emergency backup - but I am really happy so far with these Laddas. Full recharge cycle in the Stenkol is aprox. 4-hours.
StoliRaz
Ladda is the best. I buy them whenever I go to Ikea, which isn't often
dlwtrunked
Here is a video link regarding enloop and Ladda batteries; (both made at the same factory owned by Panasonic according to Wikipedia
Another place to read about rebrand eneloops
palmerjrusa
Frederick
You may want to invest in a smart charger that will numerically display a variety of cell parameters, where you can set the charging rate (mAh) for each channel, perform a discharge cycle at various mAhs (to determine the actual capacity of the cells, it's likely to be at least 15% less than the indicated capacity after a charge cycle), perform a cell refresh cycle(s) with cells that haven't been used in a while to wake them up, a diagnostic test that will indicate a cell has gone bad etc.
The problem with chargers that have only a single LED to indicate charging status is that it only indicates "finished charging" and gives no information of the actual capacity/state of the cell. You can have one cell going bad and you would never know, thus compromising the functioning of the other cells when they're in use.
The two best smart chargers on the market are:
Opus BT-C2400 Battery Charger Analyzer Tester for AA AAA NiMH NiCd Rechargeable Batteries​
Powerex MH-C9000PRO Professional Charger-Analyzer​
I own both (amongst others) and they're available from Amazon.
