PRO-97 & Rebanding
Posted on 09/30/2005 16:15 EDT
Our thanks to the "GRE Digital Scanner Design Team" for providing the following news item about RadioShack's PRO-97 and how it will my handle the 800 MHz rebanding issue:
RadioShack is continually staying abreast of the 800MHz rebanding program. We consult with industry experts regularly and are keeping a close eye on the progress of the entire rebanding effort.
Since complete details of the Motorola rebanded trunking channel plan are not yet available it is now obvious that no one can confirm for certain that any scanner can be updated or adapted after rebanding. Once the first fully rebanded systems are activated we will be in a much better position to assess the impact on our 800 MHz scanning receivers. Here is what we do know:
1. It is likely that Motorola systems with channels currently between 851-861 MHz will still function in the PRO-97 after rebanding is finished.
2. LTR and EDACS 800 MHz functionality should not be affected - just program new frequencies as they are changed in the system.
3. The PRO-97 as currently designed will probably NOT be able to handle the new bandplan for Motorola systems that are currently operating with some or all of their system channels between 866-869 MHz. These frequencies will be relocated 15 MHz down to 851-854 MHz, which requires a new 800 MHz trunking bandplan in Motorola trunked radio systems. That bandplan will not be known until Motorola installs their first few systems and we (all) get a change to see what they are doing. The 800 MHz trunking bandplan is hard coded into the radio's firmware, and cannot be changed by the end user.
If the new bandplan cannot be trunked with the PRO-97's existing hardware, RadioShack (like everyone else) would need to design new firmware (and possibly a revised hardware design). Twice in the past, RadioShack has offered a board swap program to update an existing scanner to new, improved, specifications. In those cases, there was no charge for the new board (old board must be returned) and RadioShack paid shipping both ways if the customer carried the scanner into a local store. There was a minimum service charge $39.99 and the board exchange was only done at our Fort Worth Service facility.
Again, let us remind everyone this is what we've done in the past - the actual details of any update program have NOT yet been determined, but we expect it will be along these lines.
