Im a bit new to trunking networks and whatnot and I have a question.
Grant2053
Does the trunking network for the LCG go offline at a certain time at night?
Because I have an older scanner and it just returns to scan mode looking for the data signal and finds none.
I switched to from trunk mode to manual to switch to the 857.7375 data channel and the frequency is silent.
Any thoughts?
Voyager
Perhaps the data channel changed frequencies?
I'm not familiar with that specific system, but I've never heard of a system going off the air completely at night.
nd5y
Wichita Falls, TX
Maybe it rotates control channels to one that you don't have programmed.
Try searching the band when that happens and see if there is another control channel.
RonnieUSA
Rowan County,KY (Morehead)
Any thoughts?
Do You have All of the control channels programmed into your scanner?
857.73750
858.73750
859.73750
860.73750
Lafayette Consolidated Government Trunking System, Lafayette, Louisiana - Scanner Frequencies
balibago
Banned
New Iberia
Frequency change
They are there what's left of them. I think they are using different channels for data than the old .7375s. do a good search on control channel only mode from 856-861. Remember you will also pick up two Entergy sites.
shew
PIERRE PART, LA.
if u don't have a phase 2 capable scanner...u won't hear the entergy system ....they switched to phase 2 about a month ago
