Imperial Co. VHF/UHF
W6KRU
Vista, CA
I was loading a scanner for Imp. Co. and when I went to the database to look for some vhf/uhf freqs. it was empty. I can't believe that is correct. Did an admin make an error?
radioprescott
East Central Arizona
W6KRU
Vista, CA
I am aware of the RCS, but here in SD County we still have lots of vhf/uhf frequencies. The air base in El Centro certainly isn't on RCS and should have a listing on the Imp. Co. page.
radioprescott
I understand your frustration. Here's some OLD info from Freq of Nature
Fire / EMS
Dispatch 154.4300
Tac 1 154.2650
Tac 2 154.2950
Tac 3 154.1900
Tac 4 154.2500
Tac 5 153.8900
EMS Calling Channel 153.8600
EMS 155.3250
Med 2 154.0250
Sheriff
154.9950
It appears there is not many active RR users in Imperial County . Without "ears on the ground" there, and someone willing to submit, not a lot will get entered into the DB.
W6KRU
Vista, CA
Thanks John. I'm not that frustrated. I just noticed the blank page when I went to see what might be available. I queried the database and got back a few fed and state freqs. but not many local agencies. I was just curious.
rectanglehead808
Caldwell, ID
When I go to Ocotillo Wells the only vhf or uhf i ever pick up is the race frequencies and FRS.
151-625000 WXMAN
151-715000 BFGRLY
154-980000 BJPITS
151-685000 NETWRK
151-925000 CHKRS
150-860000 FAIR
153-110000 YOKO
152-960000 CAMPNS
151-505000 CHCKR2
153.395000 BFGPT
153.380000 MAG7
155.160000 RESCUE
153.245000 CORE
151.775000 LCMOC
151.490000 BITD
154.515000 PCIRL
E5911
the lower desert
Imperial County
154.430 still active "blue" for paging. Still repeated on Superstition and Black Mtn. 800 does not work all that hot on the east side near the river, so "el centro" is supposed to monitor blue , but from my understanding they have the channel turned down. Air to ground if not on 800 is on CALCORD. White 1 154.280 still active occationally with BLM/BIA on fires
On the Law side they have the same problem on the river so 154.845
If you are on the east side, east of 98, Rural metro handles most EMS 154.325
North dunes EMS is Shaffer
South dunes Rural Metro
On a curious note, Palo Verde fire operates on RVC east due to RVC E44 running with them.
