Imperial Sand Dunes
E5911
the lower desert
Does anyone have current frequencies for imperial Sand Dunes EMS ?
Yuma is thick with BLM Rangers
I did a search on my FT7800 and found a number of digitial possibly encrypted frequencies
They used to be analog in the early 2k
biocal
Humboldt Co., CA
Check out the San Diego-Imperial RCS NextGen system. BLM has talk groups on that system. They don't appear to be running encryption, but not in the area so I can't tell for sure.
Ravenfalls
Fire runs off San Diego / Imperial system.
RR is out of date, BLM uses Ch4 for Glamis off Black Mtn. Also have CHP, F&G plus County Sheriff as LE
Ocotillo Wells is state Parks
es93546
A Member Twice
Right Side of CA on maps
A while back a friend of mine submitted a channel plan for the Glamis event and permanent channel plan for the area. This was the BLM channel plan. Either that or I submitted the plan for her. It didn't show up in the database and I can't remember why. I don't have much time, I'm backlogged with a lot of chores getting ready for winter and for winter itself so I'm not sure when I can post it. I might be able to post the document itself and not have to type it up. It will be several days till I can look at that.
1942LA
No Worse Enemy..
Law Enforcement is encrypted.
What I found for EMS (not sure if current):
North Dunes EMS-171.1625 & 172.5750
South Dunes EMS-173.6750
Ravenfalls
BLM Dunes Patrol operate on the EMS repeater? In the past they used Ch4
Ravenfalls
Wondering if the split isn't east & west as it would make more sense for Ocotillo Wells West & Glamis East.
If I were still there it's how I would have set it up.
es93546
A Member Twice
This is a 2009 Glamis channel plan:
I don't know if this will help at all since it is 12 years old. However, the frequencies match what 1942LA posted. It divides things between north and south. By now, given the 2019 reallocation of the VHF High federal government allocation Channels 10, 11, 14 & 16 would flip the output with the input to be compliant. However, if those channels are encrypted, the point is moot. Channel 12, 168.0500 is NIFC Tac 1 and I doubt it is currently authorized, as the NIFC system is only for large incidents with a Type 1 or Type 2 Incident Management Team in command.
  • 2009 CA BLM CDD Communications Plan for BLM Glamis Operations.pdf
