Important Please Read About Scanner Feed
pinellasfirefighter
Banned
seminole fl
i am no longer using shoutcast. i just bought the butel arc eazy-stream. this program has no delay and shows tex tags of the channels that you are listening to.. in order for you to listen to my feed you will have to go to http://www.butelsoftware.com/ download the arc eazy stream client its free..
after you get that install which only takes a second enter my addy.
pinellasfirerescue.no-ip.org
then make sure the ports are set on
audio port 8100
data port 8101
happy listening.....
scandan780
west central florida
Hi Gill.......i like it, works great and sounds great. I like comparing it to my pro-2055, i have only been listing for a few minutes but its interesting to see what you pick up and what i pick up. I have the s.o. and st. pete and marine plugged in mine but mine just stopped on 1-e and yours did not, interesting...... but i'm hearing more of the fire/ems on yours of course because i'm also scanning the other stuff....
Dan
pinellasfirefighter
Banned
seminole fl
yeah i have a 5 sec delay on mine so most likely i was still delayed on another fire tac channel while you pick up 1-echo.. i like the delay so i dont miss transmissions.
loumaag
Silent Key - Aug 2014
Katy, TX
Not sure why this was in the Uniden Forum, but it belong in the Tavern. The other members probably don't need a blow by blow of what you are up to.
