mitaux8030
Silent Key
I've been doing a bit of AM broadcast band DX'ing and have found that my Degen DE1103 is superior to the Redsun 2100 due to its much narrower filter... where I am in this part of the world, 9 kHz seperates AM stations, and I like to sniff out the 10 kHz stations from the USA, so a narrow filter is a must.
And this got me thinking... how easy would it be to retrofit a better filter to the two portables I have?
The Degen / Kaito 1103 doesn't need a lot of help, but fitting a genuine 3 kHz (or less) SSB filter would be nice, and it would help with digging out those 10 kHz AM broadcast stations in between the 9 kHz locals. Problem is that the Degen uses a 450kHz filter, not a 455kHz type which dramatically limits narrow filter options. Also real estate - finding the space to mount a new (larger) filter inside could be a factor too.
Perhaps a good quality Murata CFWLA450KJFA-B0 would be better than the Chequers CQ R50J filter? But thats only speculation, they're the same specified bandwidth after all, anyone know for sure if the Murata product would offer better performance?
The Redsun 2100 (locally sold as a Jaycar AR1747) desperately needs help though - its 'narrow' filter sounds like its about 10kHz barn-door-wide, despite using a 455 "I" (4 kHz) filter. The 'wide' filter is far far too wide! I feel like swapping the 'narrow' filter to the wide position, and using a CFS455J or even a CFJ455K5 filter for the narrow one.
Just thinking out loud... perhaps someone might pick up the ball and give these ideas a go. If you do, let us know how it all goes...
