PROXIMA-CENTAURI-B
- Joined
- Mar 10, 2022
- Messages
- 15
- Reaction score
- 4
No, wrong frequency range/band. An antenna like a Diamond X50 would work. You will need coax as well such as LMR-400UF. Mount the antenna outdoors above the roofline to significantly help.
Yeah, being that the Baofeng UV-5R is an Amateur Radio transceiver and he wants directional gain on transmit or receive, he'll need a dual-band antenna designed for the proper bands, not a 5Ghz dish. I really do not recommend that he even considers pressing the PTT on that radio, because I'm sorry to say, his question itself leads me to believe he does not have the proper license.
Ty for the reply. I am not sure where you are located, but here in the US, you don't a license to own a Baofeng UV-5R. I already use those directional antennas shown above for a P2P network between two distant laptops. I asked this question because I was taking a chance trying to find someone who might have figured out a way to make these antennas do more than what they were intended to do originally.
Here in the US, you are definitely allowed to push the PTT and transmit without a license; as long as it is an emergency.
Please kindly answer the question if you have the knowledge. Please do not belittle. I am sure you were also in the learning stage once upon a time. Please respect my post. Thank you.
You are correct, you don't need a license to own one, but honestly back in the day we had some issues with an unlicensed person kerchunking the repeater and playing music over it, so I get a little testy (not your fault) with people who buy amateur transceivers that are unlicensed. I still remember back in the 70's when all the CB's were being sold to idiots that ruined the band. I'd hate to see 2m or 70cm end up like that because of really inexpensive radios flooding the market.
So, if you want a dual band beam, you could invest in <<THIS ONE>> or make your own from <<THESE PLANS>> as it would be less expensive than buying an antenna that costs much more than the radio.
I apologize, I was wrong in assuming anyone unlicensed that wanted a highly directional antenna for a transceiver didn't have ulterior motives. The question itself was a red flag to me because anyone with a Novice or Technician license would already know that the antenna would not work.
Good luck.
You nailed it. Thanks for showing me the way!Ah, so you do know that those aren't "just antennas".
Well, all the other things aside (staying miles away from some of it, but not quite out in left field as some), the UV-5Rs are analog and analog only, and those radios would not be able to utilize the native capabilities of the airfiber units.
if the airfiber units in your post were linking two ROIP devices that acted as analog gateways for those Baofeng units, that would work. This is already done in a manner of sorts with all the ROIP devices that are flooding the market on a day in day out basis. The Ubiquiti devices could provide backhaul, but you would need a bit more hardware than just trying to use them as an antenna.
baofengs ---> (ROIP Gateway hardware) --> Ubiquiti ---> (air) --> Ubiquiti --> (ROIP gateway) --> baofeng.
Np. It could be done with those units, but there are much better ways.You nailed it. Thanks for showing me the way!
Yagi antennas are much easier to accommodate at Baofeng radio frequencies.
I'm not that up on parabolic dish antennas, but seems that the size to be effective is about 10 times the operating wavelength. So for GMRS, that would be about 20 feet in diameter. For 2 meters, it would be 60 feet in diameter. Yagi antennas are much easier to accommodate at Baofeng radio frequencies.
Where do you get this info and believe it to be accurate. If its ham radio you need a license. If its public safety you need a license. You can't just program channels and use at will.
47 CFR Part 97 - Subpart E - Providing Emergency Communications
www.law.cornell.edu
I am sure you have a reasonable thought process that will deduce what I meant. Please kindly don't let this post get off topic. I don't think other members nor the Mods would appreciate that.
Good luck.
