Indiana Radio ID Question
Choffa
Indiana
I was told when you put a radio on the system each radio has an ID (not the System ID) and I was just curious if anyone knew an ID I could use, someone said it might be something like 7xxxx
seamusg
Grand Blanc, MI
You might want to check out what happened to some people in western Michigan who did that for extra radios for their FD. They went to jail.
Choffa
Indiana
I wasn't asking for advice, I am asking for a radio ID--thanks anyway.
DaveIN
Founders Curmudgen
West Michigan
You may want to check with your system administrator for permission to do that. You shouldn't need a radio ID to only listen to the system.
Choffa
Indiana
I wasn't sure if the system required one or not to monitor or transmit, but was curious if there was one what the ID was...
seamusg
Grand Blanc, MI
Every radio on the system has it's own unique ID, like a serial number. It needs one to transmit on the system.
Choffa
Indiana
So how do you find out what IDs they use? WITHOUT me going and asking them.. I'd rather just find it out if anyone knows...
rdale
Lansing, MI
Why don't you explain the whole story... Everything so far sounds illegal. When he says each ID is unique, that means if you use one there's already a "real" radio using it.
Choffa
Indiana
I'll explain my situation to someone who might be able to help me but its rather long and tedious so I'll refrain from posting in throughout the forum... I realize it appears to be illegal but my use will not be for illegal activity... like I said its a long story.
