This is what I'm referring to with the 'omni-directional' thingy.
"Flexible Design: Unlike Yagi designs, the LP design has more useful lobes to the sides and back. This gives the antenna a better 360 degree omni ability, with the added benefit of gain in the direction it's aimed. Why use a unity gain discone or ground plane, when you can have omni ability and directional gain as well with the LP."
That tells me they are claiming some omnidirectional properties for their 'LP' antenna. And that is not what is typically considered a good characteristic for a log-periodic or any directional antenna.
I'm aware of how antenna modeling works and how the results are displayed. I've done that sort of thing for quite a number of years. I'm also aware of the limitations and qualifications when comparing actual antenna performance when compared to an isotropic antenna. If you cn factor in, model, all the 'left out' characteristics in an antenna's environment you still only end up with an -indication- of what it's capable of, not a factual representation. Close, but no cigar.
I can find no reference to the impedance matching system used by the 'blade' antenna. It certainly could be a 'J'-pole though. Or, considering it's physical length, a 'J'-pole array of more than one element. It could also be a center fed doublet, or several other possibilities. Without tearing one apart I wouldn't make a guess on that.
Just for grins, try using a length of wire as the receiving antenna. If that length is related to a resonant length for the frequency of interest, it will work surprisingly well. For RR frequencies (162 Mhz +/-) make it in multiples of about a foot and a half. The higher the better, and until it get's completely ridiculous, longer is better. If this thing is going to be where it won't be seen, who cares what it looks like, you know?
- 'Doc
