WA1LMC
- Joined
- Nov 14, 2009
- Messages
- 49
When I first starting using this program, there was no communications with the BC780 Scanner. The comm ports were correct and it was set for the default baud rate.
I changed the baud rate to 9600 and then to 4800 with change. However when I put it back on to the default baud rate,(which it was on at first), the communications worked.
It appears as if you have to reselect the baud rate again upon ititial setup. I also noticed that from time to time, the comm port and scanner type have to be reselected.
