The antenna that is shipped with the Nooelec brand needs a ample ground plane. I use coffee can tins. The RTL-SDR Blog dongles ships with antennas in the dipole configuration. Like rabbit ears sorta. They had the groundplane in mind. Both elements need to match in length. Tuned to 1/4 wavelength.
I can decode a P25 trunked channel with mine that is around 15-20 miles away. Hear NOAA weather radio 60 miles away on a good day. Local weather radio is 25 S-Units (measured by HDSDR's relative signal meter). I use a dipole configuration 18 inches on both legs for 160MHZ. Might try it.
-60dbm noise floor is high. Mine sits around -100dbm on VHF, -115dbm 460MHZ, -124dbm 850MHZ. Might want to move that dongle away from the computer because some computers spit out a ton of noise which will block alot of signal. Try about 20ft of USB extension cable. Not the Walmart stuff. From Amazon. Take your pick:
Amazon.com: usb extension cable - 15 to 24.9 Feet / Cables & Interconnects / Computer Access...: Electronics
