Installation in Grand Cherokee 2007
GFerg1919
Central Illinois
#1
I just purchased a 2007 Grand Cherokee and was wandering if anyone had any suggestions for mounting a scanner in it.
Is there a way to mount a small scanner like a BCT350 in the little cubby-hole to the left of the steering wheel??
I may also consider updating to pro-2096 or the GRE 600. EIther of these is probably to large to fit in that little space.
#2
Two options:
1. Inside the center console
2. Side of the center console
I feel your pain. Jeeps do not make it easy.
