Installing a Motorola Astro Spectra Mobile
krazybob
Lake Arrowhead, Southern California
I just purchased a Spectra mobile that came with no installation instructions for the wiring and I am told the wrong programming software. I purchased the following:
Motorola Spectra Radio T99DX+088W_Astro P25 VHF 110w T04KLH9PW3AN is the radio information. 1MEG 2.5KHz. AZ492FT3773
I received RSS R17.00.00 which caused others to insist that my radio is actually a Astro25. Not according to the serial number and model on the FCC Type ID web site. I'd appreciate clarification if possible.
Others have insisted that I power on the unit and provide the firmware code but they won't confirm the wiring for me. I have a DB25 connector that will plug in under the handle or adjacent to the mini-UHF connector. Which is correct, please? I also have an orange/green wire that have been shorted together and attached to a white wire. Probably the color they had handy. I am assuming that this is the ignition sense and if plugged into the fuse block the radio will power on with the key. If connected to an always on the radio will always stay on (although spikes are always a concern.)
Clarification of both the software needed and the installation would be kind. If the software the commercial vendor sent is wrong I can only ask that they send the correct software. Otherwise I am hosed.
N4KVE
PALM BEACH, FLORIDA
Like others said in your other post, the software you got is not for that radio. As for the wiring, I can't help you, as the only Spectra type radios I own are motorcycle Spectra's, & the wiring is different. Good luck.
cmdrwill
So Cali
The Batlabs image, hra4579 gif IS correct.
I think he has a HHCH radio, the W3 in the model number. HHCH, hand held control head/mic.
The main power Red lead direct to battery. 35 amp fuse. Big Black to ground near the radio mounting.
Green, is Receiver power, direct to battery plus thru a 5 amp fuse.
Orange Ignition sense, thru 2 amp fuse to either battery or IGN switch.
Control cable to 25 pin connector under main battery power jack, left side.
krazybob
WOW! Thank you guys. That's all I've been looking for. But note that I have a W9 head. I just didn't want to willy-nilly plug into the wrong port and perhaps cook a nice radio. Please also note that I was doing my best not to ask the same question all around but I felt stymied on another site.
The GIF is awesome! It shows clearly the different choices that I have as a mobile installation. I have printed it out. Thank you John for the links and the rest of you for the advice.
I also have purchased two mobile extenders currently on 450MHz that I need to bring down to 440. That's not a problem from what I've read. Re-crystal it and give it a tune-up. But where can I find programming instructions?
I assume that a mobile extender plugs in in between the handle? And has been said the main control cable plugs in just under the power jack? A VRS document discussing programming of the MPL and the stuff I don't know about would be quite helpful. I see it listed but
73 de...
Drum roll please:
R117000
N080303
CNTLHD24
T04KLH9PW9AN
412ACL3281
1 MEG
2.5KHz
Thank you! I appreciate all of you.
Namaste
Chief40of2001
Oconomowoc WI
Gary,
Are you available for assistance/ info about motorcycle mounting of astro spectra radio and accessories?
