I will be purchasing and installing a multicoupler and was curious to know if there is a preferred coax to run from the coupler to the scanners. I will be feeding the coupler with Times LMR-400 from the discone, but I feel that is not going to be flexible enough to feed the handheld scanners. Some of the scanners will be fixed install so I can use a thicker cable if needed.
I realize it is a short run (4' or less), but I want to put every advantage in my court when it comes to signal loss. Also, I will be needing BNC ends on the cables and would prefer not to use an adapter with the exception of some SMA connections. Ultimately, I would like to have a commercial company make the cable assemblies for me.
Is there a high grade/quality cable a little thinner than standard RG8 thickness? Something along the lines of a Mini 8/U but higher conductivity ratings.
I will be installing a Diamond Discone up around 15'. The height is limited due to homeowners deed restrictions, so I need to make sure I get every ounce of signal to the radio and prefer to not use a preamp. I primarily monitor VHF Air, Mil Air and 800/900 mhz.
I realize there is a million threads on coax and also on multicouplers, but I didnt see much of the two combined, so I decided to post.
