Interesting personality test
#1
www.hypnoid.com/psytest2.html
I had no idea what I was doing but the results are amazingly correct!
Quiet and very self-assured, you tend to keep your own council. Pragmatic and practical to a fault, you are not one to worry about the finer points of philosophical discourse. In fact, because you are very much an individualist, you often finds yourself at odds with the established truth or the wishes of the majority. You will often earn the wrath of an employer by taking upon yourself decisions which are rightly those of your manager. You are not one to take credit unless it is deserved. Similarly however, you will also not happily give credit where it is not due. In a romantic relationship you can be very frustrating. While you do care deeply and sincerely, and are willing to work at a relationship, your confidence in your own abilities can on occasion make it difficult to see the world from a partner’s point of view. Quiet and stoic at times, you can drive a more emotional individual completely up the wall. You can become overstressed and fatigued without knowing it. Taking time to rest between bouts of hard work can help to prevent a breakdown later on.
#2
That was interesting.
I did however expect the final answer to be something to the effect of...This shows you spend way too much time on the internet."
But I enjoyed that one.
