Interference Eliminator Codes
Mollys70
Wichita Kansas
If I wanted to monitor a local business that uses Motorola CLS 1410 radios, is there way to input the code?
They use/are on 467.8500 with a code of 111. I work there & thought it would be fun to listen from home. Only live a mile away.
I can hear them just fine, but get a tone with static on a constant basis. I have played with CTCSS & have a great antenna.
using 996xt
newbie here so thanks in advance.
Mollys70
Wichita Kansas
I am using ARC XT pro software. I just entered codes in the PL/DPL area. Am I thinking right? radio is silent now. Any other setting I should look at?
Mollys70
Wichita Kansas
OK & Thanks, I am trying this. I have the codes in I believe. I used my software & chose audio type to analog, and input the codes in the PL/DPL as the table showed. Is this correct? Using ARC PRO software.
