is the DB25 accessory pinout on the M7100 the same as the M7300
LostSignal
SoCal
some of you have probably seen my first post and know that I work along side the fire departments. Anyways, I've been looking desperately for an answer on the accessory pinout for the M7300? Is the M7100 accessory pinout the same as the M7300???
I just need the PTT pins that are used (i.e. PTT+ and PTT-) AND the audio pins as well (i.e. when you key the MIC what are the MIC audio pins)?
Thank you guys for helping me out!!!
IF there is another thread about this, I HIGHLY apologize for a second thread.
I MUST build a radio interface cable for a fire station in Colorado. Again, thank you guys for reading.
Radioman96p71
Polk County, IA
Do you need the pinout for the 44-pin connector on the radio unit or the 25-pin connector on the control head?
I'll post a brief pinout since this forum hates it when i try to post a nicely-formatted version:
Pin:
1 - Ground
9 - Input 2 (you'll need to assign this to PTT, or Input 1. Put this pin to ground to key radio)
22 - Input 1
24 - Ext_Mic (This pin is summed into the normal mic audio path)
The 'normal' PTT and Mic lines are only present on the mic jack itself, but I have interfaced several radios this way and it works just fine.
Hope that helps!
LostSignal
SoCal
Pin:
1 - Ground
22 - Input 1
Hope that helps!
There is no control head. I have to work tomorrow and I'll see if I can post a picture that was sent to me of the back of the radio itself. There is a 9pin female and there is a 25pin female on the back of the unit from what I remember seeing in the picture.
I can tell you this, that in one of the pictures, it is an M7300 mobile according to the sticker on the radio.
Thanks for everyone's help thus far though...
LostSignal
SoCal
here is the picture of the radio
to DisasterGuy, the radio has a DE9 connector and a DB25 connector. Other than that, as you can see in the picture, there are no other interface ports. Either way, I thank you for constantly helping me.
Here are the pic's:
LMR_Dude
Pinout of the 7300 accessory cable is on Page 92 of the install manual: http://www.texasbidsystem.com/xfer/PublicSolicitation_doc.asp?SDIR=108467&2-M5300_Installation Manual.pdf
Disaster Guy posted this for you, I've looked at it and the info is good.
You won't find PTT line, use either INP1 or INP2, check your OPTIONS, EXT I/O settings to see which the radio is programmed for.
Be sure to use the CAN terminators or bad juju will occur...
DisasterGuy
Maryland Shore
The photo that you have posted is the CH-721 control head, not the actual radio. You would interface to it using the CA-011854-001 CH-721 Option Cable or you could simply build your own if you wish. The pinout is attached. As mentioned, using the option connector for PTT will require programming.
LostSignal
SoCal
THANK YOU ALL!!! I will let you ALL know how it turns out. My boss agrees that their radio shop needs to tell me what PTT is programmed on in order for me to "build" their radio interface cable. YOU GUYS ARE JUST AWESOME!!! I'm NOT a radio tech, but am slowly being put into that sorta position. My MAIN responsibility is the main alerting unit and the back-up alerting unit... NOT radios. However, I do build, MOSTLY, Motorola cables (i.e. CDM, XTL, MCS200, etc) radio interface cables. Anyways, that is just a little bit about what I do just to give you guys some idea about me.
Well, AGAIN, THANK YOU ALL!!! I'll make sure to let you guys know how it went.
Take care people!!!
BTW, going for my HAM here, reading the Gordon West book as of right now. I'm hoping that having my HAM license, it will help me understand radio systems a bit better. Right now, it's, more or less, learn as I go.
LMR_Dude
I've interfaced a M7300 to a wireless David Clark used in fire engines. Knowing which input line the radio is expecting is key .
What the use of your radio and why do need to build this cable? I'm just curious. You mentioned this is for a FD in Colorado and I work on public safety radios in the Denver area.
LostSignal
SoCal
without going into great detail
When CAD/dispatch alerts a fire station(s) one of the devices that I'm responsible for keys the radio and gives information on that particular radio channel, in this case it is going to be keying the M7300 that you see in the picture.
Thanks for asking and thanks for your help as well. Like I said, I'm NOT a radio tech, but I am familiar with the pinouts of CDM's, XTL, MCS2000, AstroSpectra, etc but I am new when it comes to Harris. More and more fire stations that we deal with are utilizing Harris M7300 or the CS7000 desktop station. This just happen to be one of those jobs where it was really NOT all that sure WHAT kind of radios they were going to be using... a long story in itself. Hence, the desperation of finding the pinout.
Again, thank you and I will let you guys know how it went.
