Is the IRP down
OldDeadOne
Silent Key
Fayetteville,WV
I have a earlier post about shutting the IRP down that was cancelled,I just turned on my scanner so I will be listening for any stuff and will report back on this.
Nope,it's up,just heard 6173(Tac 4 Charleston) so it ain't down.
wvscanner
Beckley, WV
I know I got boone on the 16th on 453.3375 was trying to find what the new ssid turn up on some of the sites, I could not get the signal good enough to get it. I also had 460.275 site 222 but did not figure where it was at.
OldDeadOne
Silent Key
Fayetteville,WV
I'm too far away to try help listening in on this maybe someone else will chime in,it's been down since you first noticed this?
wvscanner
Beckley, WV
Boone is hard to get in Beckley, I might get a chance to check into sometime next week. On the other hand I'm getting them on tg4929 on the pax tower, even as of today.
wvscanner
Beckley, WV
hmoutdoors
Madison WV
Thanks guys I am not hearing anything and I am very close to the tower I can not pick up the Beckley sites I am not hearing tg 4929 at all
OldDeadOne
Silent Key
Fayetteville,WV
Are there any other towers nearby? What kind of scanner do you have(if you've mentioned it before,I've forgotten,sorry :) ) . Try attenuation or whatever it's called if you have other towers nearby and see if you can pick up the tower.
ab8sn
Camden On Gauley WV
Wvirp
I was in the Chas. area yesterday and I also got TG4929 on the Chas. Site as well as TG9771 ( DHS 1) later on in the day someone was doing a test count.
I've got a stupid question for you guys, I noticed that within the last two weeks some of the sites are now at the bottom of the list and is a site 2 now instead of 1 like before. What exactly does that entail? Thanks in advance
73s
Chad
hmoutdoors
Madison WV
No other towers working. Malden or Kopperston are near but I can not pick them up I am using a Pro96 and Uniden BCD996T
wvscanner
Beckley, WV
Ghent and Kopperston must of been worked on today. They are now on zone 2. When Pax did that the signal was not as strong. As of 3:18pm Kopperston is running you can log onto my feed to hear it if anything is on it.
wvscanner
Beckley, WV
Is it on the same freq. as before? Can you verify what site number it is ruining since most are changing.
Thank you
hmoutdoors
Madison WV
It appears to be 453.3375 did not see a tower Are you receiving them on Kopperston ? This is on the Boone site just not showing a tower #
wvscanner
Beckley, WV
Its own SSID should show, for its neighbor site's they seem to be a work in progress, Pax has changes a few times over the past 3 weeks on its list. Ghent change the day after I did the first look on it.
