Is there a way to reset a scanner?
MVCTCCJGIRL05
Ohio
I have a Pro 95 trunking scanner and I was wondering if there is a way to reset it, like delete everything?
I'm wondering because I, by mistake, hit the wrong button listening to the trunked channels, which in turn saved all my trunked IDs. I didn't want to do this. I tried taking all those out and putting them back in, but they are still saved.
drew6553
Supply
reseting
turn it off then on and i belive pressing 0 then 1 initializes it i haven't done it for awhile but it'll completely erase the memory reseting it will just leave them in there so initializing is your best but most work heavy choice
MacombMonitor
Click here:
http://support.radioshack.com/support_electronics/doc67/67349.htm :D
My PRO-94 can be reset by pressing the # 2 & 9 keys at the same time
with the radio off then turning it on and off again.
I have found that this works with a lot of scanners, including the older
Uniden BC-200 & BC-145.
Good luck! SOOO much reprogramming!
