Sentinel: Is Uniden database update site down?
stetsonbob
Canton, OH
I have not been able to update my data base this whole week. I am using sentinel software for sds 100. I click on Menu >Update master database then it times out.
stetsonbob
Canton, OH
spectrum in Ohio. All security turned off and I still can't connect to server. Any suggestions? I was able to two weeks ago and I did not change anything.
tvengr
Well Known Member
Baltimore County, MD
When you update the database using Sentinel, it only updates the database in your computer. The database in the scanner is not updated until you write to the scanner, even if the scanner is connected to the computer when you update the database.
RT48
Cuyahoga County, Ohio
Open a command prompt window and type "nslookup ftp.homepatrol.com" and hit enter. If that works, then DNS is working. Next type "ftp ftp.homepatrol.com" and hit enter. Tell us any error message you receive.
RandyKuff
Lorain, Ohio
That error message can mean your computer has no network connection... Or you are loosing network connectivity while trying to update...
Just unplugged mine from my network and I see the same error when trying to update the database...
You using WIFI or an eithernet cable to connect?
a417
turn all your networking stuff off (wifi, modem, router, etc) and, and turn it all back on again. Once lights return to normal, reboot your computer.
