iScan PRO 107 Conventional vs Trunked
I'm new to Trunked Systems, but I've noticed something odd with my RS iScan PRO 107. If I create a Playlist with only Trunked Systems and play only that Playlist, I get a lot of activity from the Trunked Systems. If I add conventional channels to the Playlist or created a separate playlist and have it scan both playlists I get very little activity from the Trunked Systems. Has anyone else ran across the behavior?
