Iscan software program
ASTROAL
brooklyn ny
Does anyone know how to fit the ISCAN software program on a 10" hp mini laptop?
The bottom part ot the program is not visable to advance to the conventional screen.
ASTROAL
brooklyn ny
It is set to the max that I can see 1024 by 600.I understand that some software programs
need 1024 by 768.Can I get the higher setting ?
iMONITOR
MACOMB, MI.
Yes it appears iSCAN wants 1024x768.
Try right-clicking on your Desktop, then left-click on Properties, then left-click on the Settings tab, the see if you can drag the Screen Resolution to a higher resolution.
If that doesn't work, try grabbing the top edge of the iSCAN window, and pull it down a little, then grab the top bar of the iSCAN screen and pull the iSCAN window up a little.
ASTROAL
brooklyn ny
I went to the monitor advanced button and I unchecked
the Hide modes that this monitor cannot display.I was then able to
slide the screen resolution to a higher number.1024 by 768.I get the
full screen of the program now by moving the page up.The bottom settings were blank
but when I updated the software the settings appeared.I can live with moving the screen
up if I have to.Thanks for your help,this might answer someonelses question.
