Issues again?
scottct1
Newington, Connecticut
#5
Is audio3 down?
Getting notices in my email that my feed is down.
Checking the machine it is trying to connect to audio3.broadcastify.com but is not getting connected.
Was working fine about 30 minutes ago.
Anyone else?
blantonl
Founder and CEO
Staff member
Shavano Park, TX
#17
audio3 died - we failed it over to a new box.
If you are using a barix streaming device the new ip address is 174.37.110.68
Otherwise, stop and start your feed and all should be well if you are on audio3
