Issues
whitesox4life
Grant Co, IN
I bought a Cobra 25 LTD a couple years ago and just recently put it back in my car. I was using a cheap Walmart CB antenna. I then purchased a Wilson Little Wil antenna and am having the same issues of very very limited rx range (approx 1 mile) and 100 yd tx range. I have never been inside the radio. What have I done wrong and what do I need to do in order to have full operation of this unit? I have considered selling it and picking up a Connex 3300HP.
sdeeter19555
Reading, PA
There should have been instructions in with the little Wil (assuming you bought it new) about adjusting the standing wave ratio (SWR).
However, my thoughts are you have some other issue because SWR doesn't affect receive. See if there is a reputable CB shop local to you and see if the receiver and transmitter are turned down or off frequency.
wyomingmedic
There are a lot of possibilities here.
1. As was mentioned, you need to make sure the antenna is properly tuned and the radio is happy. This is probably your number one most common problem. Along those lines, make sure that the coax and connector are all intact. Seemingly small problems can be big issues.
2. Make sure the radio is intact. The connectors on the radio can fail internally and may need repaired.
3. For receive, you need to have a minimal amount of noise as possible. If every time you turn your radio on, and the S meter is pegged, you may have a noise issue. That can mean that a much stronger signal is needed for you to hear them.
4. Make sure there is nothing extra in the line of the coax. Meters, amps, splitters, etc. You need to make sure your basic setup (radio and antenna) are functional.
5. How is the radio wired electrically. I have seen some extremely odd problems manifest themselves from low or very high voltages. Crappy transmit audio is the most common.
WM
robertmac
Unusual
Probably not on CB when the skip is rolling in.
