ITAC, etc
Roach112683
Wilmington, DE
How do you program the ITAC frequencies into the scanner banks as they are different than the trunked frequencies and just standard analog? Do they have to be in a separate bank or how does that work?
Septa3371CSX1
Drexel Hill, PA
Just program them in wherever your heart desires. Just be sure to set the mode to FM or CTCSS. If you program in CTCSS, the PL Tone for all of them is 156.7.
Audiodave1
Chadds Ford, PA
As an FYI regarding the Delaware ITAC's, You will only hear them used if the trunk system goes down hard.
I believe on Tuesday or Wednesday there is a roll call on 866.0125 between various troops and departments.
