Jackson CountyVHF systems
#1
Does anyone know the Digital frequencies for Jackson County Fire and if any of the VHF repeaters are still working properly. I seem only to be hearing certain traffic. Yes they use digital 800 but I have it completely programmed and no I am not hearing the traffic on it. It seems there is other frequencies being used.
#3
Jackson County Fire Repeater
This is the Fire Frequencies listed for Jackson County, it seems their is 2 reapeater systems, and is cutting of radio traffic.
Can anyone help with proper alienment?? The repeater for Fire Dispatch is 154.205 PL179.9 and Input 150.805.
It seems that they have added and Radio Reference hasn't updated properly.
Thanks for the help.
1 154.20500000 11K2F1D FB2 1 100 50.000 38.97278 -86.16750 FREETOWN JACKSON IN
1 154.20500000 11K2F3E FB2 1 100 50.000 38.97278 -86.16750 FREETOWN JACKSON IN
2 150.80500000 11K2F1D MO 200 0 45.000
2 150.80500000 11K2F3E MO 200 0 45.000
2 154.20500000 11K2F1D MO 200 0 45.000
2 154.20500000 11K2F3E MO 200 0 45.000
3 150.80500000 11K2F3E FX1 2 0 15.000 JACKSON IN
3 150.80500000 11K2F1D FX1 2 0 15.000 JACKSON IN
3 155.67000000 11K2F3E FX1 4 0 100.000 JACKSON IN
3 155.67000000 11K2F1D FX1 4 0 100.000 JACKSON IN
4 156.24000000 11K2F3E FB 1 0 100.000 38.79739 -85.84308 Crothersville JACKSON IN
4 156.24000000 11K2F1D FB 1 0 100.000 38.79739 -85.84308 Crothersville JACKSON IN
5 156.24000000 11K2F3E MO 250 0 50.000
5 156.24000000 11K2F1D MO 250 0 50.000
6 151.15250000 11K2F1D FB2 1 100 100.000 38.97278 -86.16750 FREETOWN JACKSON IN
6 151.15250000 11K2F3E FB2 1 100 100.000 38.97278 -86.16750 FREETOWN JACKSON IN
7 151.15250000 11K2F1D MO 200 0 100.000
7 151.15250000 11K2F3E MO 200 0 100.000
7 155.67000000 11K2F1D MO 200 0 100.000
7 155.67000000 11K2F3E MO 200 0 100.000
milf
Careful, I CAN hear you!
Indianapolis, IN
#4
We can only update what you folks out there submit to us. If you find other frequencies and tones in use, submit them to us. Also you want to check your settings on your scanner as for delay. If your missing replies, then your delay is not set right for the frequencies.
#5
Ref to my reply, 154.205 PL 179.9 Input 150.805 PL 179.9 is Dispatch 1 But their seems to be other frequencies
listed. Can you explain this???
