Jackson Hole Airport (Wyoming) Crash 3
Somewhere in the Rocky Mountains
#1
I put this in the Wyoming thread with no luck, so I am trying here. I am doing research on unique/one-of-a-kind fire apparatus, and was wondering if anyone could provide pic's or a link to pic's of this rig, a 1996 Peterbilt/Darley apparatus.
Thanks,
Frank
fnnm1062
longtime member
Oakland County, MI
#2
did you try contacting the airport crash, fire, rescue crew? They might be of help, or if your are local to the airport seeing if they would let you stop by.
#4
Crash 3
Hello lakekid313 & RHFD910
As I've said in the first post, I am doing research, as a personal hobby, on unique/one-of-a-kind fire apparatus. This truck was built by Darley on a 1996 Peterbilt all-wheel-drive chassis. This rig features a 2800 gallon water tank, 1250 gpm pump, foam cells, dual deck guns, and a 50' Snozzle, among other things. As far as I can determine, this was the only truck in this configuration built for airport use. I am in Colorado, so I can't really go out there in person, much as I would love to, so I am hoping someone on the Board could help out.
Thanks,
Frank
