Jaguar 700P question
SherwoodPolice
#1
I have a Jaguar 700P and have programmed it with Programmer R18. I have flash S15R05E05 with DSP I4R05K01, but my Option 29 is not showing to be on. I was reading somewhere in this forum that Option 12 must be present in order for Option 29 to work. I understand what the Feature Options are and here is a list of what is in my radio.
04 07 08 16 21 23
My question is do I have the correct DSP and Flash in order for Option 29 to be present and enabled?
Any help would be greatly appretiated.
Radioman96p71
Polk County, IA
#2
To get Features enabled you need to have a Feature Encryption Code entered in the radio that allows for it. If your radio doesnt have a feature (29 in this case) you need to call Harris TAC and purchase it, then they will send you the code to enable it. No version of radio code/dsp flash will enable features without the proper FEC. There are some 'test' radio code that used to enable all features in the MRK/Orion series strictly for testing, but I haven't seen anything like that for the Jaguar line.
SherwoodPolice
#3
Thanks Adam. I am an LEO and I am trying to use this radio as a mirror to my pacset that I use. But the pacset I use is a Jaguar 7100ip and was programmed with a more recent version of Programmer. Thanks for your help!
