Jaguar 725P???
rmiles
Bel Air, MD
https://gullfoss2.fcc.gov/oetcf/eas/reports/ViewExhibitReport.cfm?mode=Exhibits&RequestTimeout=500&calledFromFrame=N&application_id=521598&fcc_id='OWDTR-0014-E'
If you look at the last file, it a operator's manual for the 725P & 725PI Jag. I've seen the 725M's out there, but not the 725P. So what's the "rest of the story" behind this mystery radio?
JungleJim
If you sort through the documents on that page you will find the cover letter with the following paragraph:
In order to prevent confusion please note; in the original report the radio was referred to as the Jaguar 725P, due to marketing considerations we have changed the name to the Jaguar 700P, this is merely administrative no technical difference is meant to be implied.
rmiles
Bel Air, MD
I missed that. Thanks for pointing it out. Originally, I went there hoping to find a copy of the elusive operator's manual. I've been trying to locate a PDF of one for a couple years now, to no avail. The one posed there leaves a lot to be desired. It's nothing like the operators manual for their other radios. Anyone out there have a newer version than whats posted on the FCC site?
